wefjeber
Sep 10, 2020Aspirant
COSTCO RBR750 2 Satellites slow wired speeds
I just bought an OBI RBR750 from Costco with 2 Satellites. My home has Cox Gigablast (1,000MB/S) and is wired so each Satellite has the wired backhaul. In my office, I use Satellite 1's additio...
HappyFlavor
Oct 26, 2020Aspirant
One Statlite is directly connected to the 750 , the other is connect via "wifi". I have the Cox Giga and standing directly in front of the RBR750 I get max wifi speeds of 250mps, and its only worse as i walk away from it.
Oct 26, 2020Guru - Experienced User
What happens if you swap the RBS with each other? See if the problem follows and tracks with the working RBS.
Be sure your using good quality LAN cable. CAT6 is recommended.
- HappyFlavorOct 26, 2020Aspirant
The issue is not that one Satalite is working and the other is not, they are both showing up in the Orbi App Network Diagram and "working" the problem is that the degradation of the speed in wifi is much greater then the projected 30%. I am only getting 250 mps max (standing directly in front of the router) on a Giga Connection. I will check on the quality of the cable.
- FURRYe38Oct 26, 2020Guru - Experienced User
Would need to swap RBS around to see if the problem continues as well.
What wireless device are you using when your speed testing?
I have moved and switched the Satalites around and it's all the same; but regard;Ed's of the location or order of the Satalites, why would my speed be only 250 mbps when I am standing right in front of the RBR 750. Could it be one of the settings?
- Mikey94025Oct 29, 2020Hero
HappyFlavor wrote:I am only getting 250 mps max (standing directly in front of the router) on a Giga Connection. I will check on the quality of the cable.
Other speed diagnosis steps can be found in the community faq: https://community.netgear.com/t5/Orbi-AX/Community-FAQ-My-Orbi-speeds-are-slow-inconsistent-and-don-t-my/m-p/1984305/highlight/true#M7944
You will not get giga speeds over wireless. Unless you have an AX device you will also unlikely get AC speeds over 300-400 Mbps. Verify that you get reasonable AC speeds close to your base station (turn off your satellite if necessary to ensure you're connected to your base station), then continue to diagnose your wireless speeds.
Wired speeds are a different situation and you should be able to get close to gigabit if wired to the base and if your upstream ISP supports it and if you don't have Double NAT.
