BuckyFan53066
Apr 07, 2021Aspirant
CP1025nw Printer will not connect to WiFi
AX6000 (RBK852) DOES NOT APPEAR AS A VALID MODEL IN THE DROP-DOWN LIST! Recently replaced my old RBR50/RBS50 with an AX6000 (RBK852). My HP CP1025nw printer always maintained a rock solid connect...
Apr 07, 2021Guru - Experienced User
You'll need to contact the pritners mfr for additional help and support and information regarding there product.
- BuckyFan53066Apr 07, 2021Aspirant
Thanks, but no. I didn't need to contact HP to do the setup when I connected to the RBR50 a few years ago, no reason I should need them now.
printer's, not "pritner's"
their, not "there"
- FURRYe38Apr 07, 2021Guru - Experienced User
Try disabling AX mode on 2.4ghz on the RBR under Basic tab/Wireless settings
Try setting CTS frm 64 to 2347 Under Advanced Tab/Advanced Settings/Wireless Settings
Should any of this still fail, you'll need to contact the mfr for additional help and support for there product.
Good Luck.
- Mikey94025Apr 08, 2021Hero
FURRYe38 wrote:Try setting CTS frm 64 to 2347 Under Advanced Tab/Advanced Settings/Wireless Settings
Agree, I would set CTS/RTS Threshold to 2347 for both bands. If it works then also undo the other support recommendations (i.e., turn WMM back on).
- schumakuApr 09, 2021Guru - Experienced User
BuckyFan53066 wrote:Thanks, but no. I didn't need to contact HP to do the setup when I connected to the RBR50 a few years ago, no reason I should need them now.
That's a reality-ignorant approach. Many wireless clients, embedded and generic computer systems had and some still have issues when it comes to associate with Mesh and/or WiFi 6 systems. Even the very popular Intel clients had many - from unable to "see" wht SSID on air to various connectivity and reliability issues. A good start is to consult the HP downloads for your printer, and update the printer firmware.
