BuckyFan53066
Apr 07, 2021Aspirant
CP1025nw Printer will not connect to WiFi
AX6000 (RBK852) DOES NOT APPEAR AS A VALID MODEL IN THE DROP-DOWN LIST! Recently replaced my old RBR50/RBS50 with an AX6000 (RBK852). My HP CP1025nw printer always maintained a rock solid connect...
Apr 07, 2021Guru - Experienced User
You'll need to contact the pritners mfr for additional help and support and information regarding there product.
BuckyFan53066
Thanks, but no. I didn't need to contact HP to do the setup when I connected to the RBR50 a few years ago, no reason I should need them now.
printer's, not "pritner's"
their, not "there"
- FURRYe38Apr 07, 2021Guru - Experienced User
Try disabling AX mode on 2.4ghz on the RBR under Basic tab/Wireless settings
Try setting CTS frm 64 to 2347 Under Advanced Tab/Advanced Settings/Wireless Settings
Should any of this still fail, you'll need to contact the mfr for additional help and support for there product.
Good Luck.
- Mikey94025Apr 08, 2021Hero
FURRYe38 wrote:Try setting CTS frm 64 to 2347 Under Advanced Tab/Advanced Settings/Wireless Settings
Agree, I would set CTS/RTS Threshold to 2347 for both bands. If it works then also undo the other support recommendations (i.e., turn WMM back on).
- BuckyFan53066Apr 09, 2021Aspirant
Made change to CTS/RTS and was able to establish connection! Did 'undo' on other NG support recommendations and WiFi connection to printer was lost. "Undid the undo" and put all settings back to NG recommendations (above) and left CTS/RTS at 2347 (which had just previously worked) and connection will not re-establish. Pretty much ready to give up at this point.
- schumakuApr 09, 2021Guru - Experienced User
BuckyFan53066 wrote:Thanks, but no. I didn't need to contact HP to do the setup when I connected to the RBR50 a few years ago, no reason I should need them now.
That's a reality-ignorant approach. Many wireless clients, embedded and generic computer systems had and some still have issues when it comes to associate with Mesh and/or WiFi 6 systems. Even the very popular Intel clients had many - from unable to "see" wht SSID on air to various connectivity and reliability issues. A good start is to consult the HP downloads for your printer, and update the printer firmware.
