Retired_Member's avatar
Retired_Member
Aug 10, 2022
Crash after speedupgrade
Hello
My system has been stable for 1 year now, only reboot after power outage or firmware updates, but yesterday I got my internet connection upgraded from 500Mbit to 1Gbit.
First thing I wanted to test was the new speed. I fired up Steam and started to download a large game, about 120GB. After 30-40 seconds at speed 103MBytes/s the router stops responding to ping and the purple light illuminates on the RBR850, and I need to unplug and plug the power to get it back online.
I can see people having problems in other discussion about large downloads, but I have never had this before upgrading the linespeed. I tried about 5 times today and same thing happens every time.
After some try and fail with the settings, I disabled Armor (which I have paid a 1 year subscription for) and that seems to make to router stable again.
Anyone experienced the same?
Orbi in routermode
HW: RBR850, 2xRBS850 and 1xRBS750
Firmware:V4.6.8.5
Internetprovider: Bridge mode (so the problem is not suspected to be here)
Factory reset done with no different result
  • FURRYe38's avatar
    Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
    Turn off and unplug modem.
    Turn on computers and rest of network.
    What CAT# lan cable are you using between the RBR and modem/ONT?
  • It could be a bad power adapter as well. Try to swap out the power adapter from one of the satellites and see if it fixes the problem.
