entropy47
Dec 27, 2021Follower
Cross-product compatibility with eth backhaul?
I currently have a simple setup - one base AX6000 and one RBS850 satellite, linked wirelessly.
I would like to add an outdoor unit with ethernet backhaul to the root node. I would like this unit to be wifi 6 so I don't have mixed network quality in the future - so it looks like my only option is the NETGEAR Orbi WiFi 6 AX1800 Mesh Add-on Satellite (RBS350).
Will this unit work okay with my existing setup, including ethernet backhaul? I'm not sure how well these systems interop, but I know my Amplifi units hated it when you tried to mix and match.
1 Reply
I believe the 3 series was added to the compatibility support in a prior FW release so the 3 series should work:
