Jimbo84
Mar 03, 2022Apprentice
CTS/RTS and "hidden node problem"
Hey all I have my CTS/RTS value set to 2100. I recently changed the setup on the RBK752 to use a wired backhaul (15m CAT6a run). I've reduced 2.4Ghz power to 25% and 5Ghz power to 50%. I have ...
Mar 05, 2022Guru - Experienced User
Jimbo84 wrote:
Hey all
I have my CTS/RTS value set to 2100. I recently changed the setup on the RBK752 to use a wired backhaul (15m CAT6a run). I've reduced 2.4Ghz power to 25% and 5Ghz power to 50%. I have zero collisions reported by Orbi on the WAN, LAN or WiFi interfaces. And I get a nice hand off between the RBR and RBS when moving around.
My question - does a 2 node setup, with wired backhaul, suffer from the "hidden node problem"? I was looking on Wikipedia and the example given shows 3 stations communicating with each other. As the RBK752 is a 2 node kit, am I safe to assume this is not an issue here?
Would the more knowledage suggest increasing CTS/RTS to stop unneccessary overhead on the network? I don't think I'd disable it fully, but perhaps increase it a bit more?
The reason I had lowered the value is that in the early days of Orbi ownership I had trouble with phone calls over WiFi. Calls would go silent, drop off completely, or voices would sound garbled (Android 11 / Android 12 devices). But saying as I'm now wired on the backhaul and seeing there are no collisions I thought I'd ask to see if upping CTS/RTS would be a wise decision? :smileyhappy:
Thanks.
- Jimbo84Mar 05, 2022Apprentice
Hi FURRYe38 - it is running the beta FW (v4.6.7.5). The ISP Edge Router is a Zyxel NR7101. It is a 5G external POE Router.
Thanks.
- FURRYe38Mar 05, 2022Guru - Experienced User
Has a factory reset been performed since last FW update?
Is the Orbi in router mode or AP mode with this ISP modem/router?
If router mode on the RBR, have you tried setting up the DMZ on the ISP Modem for the RBR if the modem is in router mode?
- Jimbo84Mar 06, 2022Apprentice
FURRYe38I will do a factory reset as per the other topic as I do want to iron out the glitch with the 2.4GHz connectivity problem. I know we're going slightly off topic here so I do apologise but... at the moment, no, both the Orbi and the Zyxel are in "router mode". I have manually disabled DHCP, WiFi, etc on the Zyxel and then turned off NAT on the Orbi. However, I do plan on doing it "correctly" - so I am looking to enable IP Passthrough on the Zyxel - and basically handoff the ISP/WAN IP to the Orbi. The Zyxel then just becomes a modem.
I wanted to ask more knowledgable people such as yourself - When I come to turn this on, the Zyxel asks for a fixed MAC address of the LAN client. As I understand it, this would be the RBR. Would I add the MAC address of the WAN/Internet port for the Orbi, or the actual MAC of the RBR unit?
At the moment I have also have a static IP setup on the Zyxel for the Orbi WAN port, which is in the same IP range as the Zyxel (192.168.1.x). Within "Advanced > Internet Setup" on the Orbi, I then have that IP address added under "Internet IP Address" field. And the Zyxel Router IP I have in the Gateway field.
Will I need to change any of that when enabling IP Passthrough? Do I set the "Internet IP Address" back to "Get Dynamically IP Address From Router"?
And lastly would I need to change any of the ethernet cables around or do they stay connected just the same as now?
In my mind I'm thinking:
- Remove Static IP entry on Zyxel
- Enable IP Passthrough on Zyxel (unsure as to which MAC address to use however)
- Set Orbi Internet settings back to "Get Dynamically IP Address From Router"
- Reboot Orbi RBR and then reboot Orbi RBS
Thanks. :smileyhappy:
