Chuck_M
May 24, 2020Mentor
CTS/RTS Values With Firmware V3.2.15.25
New firmware (3.2.15.25) in for several days and things appear to be fine & very stable across the board. Out of curiosity (after reading a post on here) I checked the CTS/RTS values and they are...
Mikey94025
May 24, 2020Hero
Great observation! Thanks for reminding me to check the CTS/RTS values after the firmware upgrade. I did (chose) not reset my Orbi AX after the firmware upgrade and my values stayed at 2347 so I don't need to change anything.
I would stick with 2347 unless there's evidence not to. We know that 2347 works better and is more compatible than the previous/low default values. Perhaps someone else here knows if/why 500 would be a better default.
- FURRYe38May 24, 2020Guru - Experienced User
I factory reset mine and the defaults are still back at 64 after 15.25 was loaded the other day. I moved mine back to 2347.
Mikey94025 wrote:Great observation! Thanks for reminding me to check the CTS/RTS values after the firmware upgrade. I did (chose) not reset my Orbi AX after the firmware upgrade and my values stayed at 2347 so I don't need to change anything.
- Chuck_MMay 24, 2020Mentor
I wonder if the regional releases may have had different defaults.... Anyhow, I reset to 2347.
Entire system is smooth as silk. Nearly 100 devices (including Sonos, pool, nest, synology, rachio, chamberlain, etc) are playing well.
- AhmedEssamMay 26, 2020Aspirant
the CTS/RTS 2347 might cause you connection problems with some devices like playstation 4. I think the new firmware is late fixing this issue. I wouldn't push it above the 500
