Chuck_M
May 24, 2020Mentor
CTS/RTS Values With Firmware V3.2.15.25
New firmware (3.2.15.25) in for several days and things appear to be fine & very stable across the board. Out of curiosity (after reading a post on here) I checked the CTS/RTS values and they are...
AhmedEssam
May 26, 2020Aspirant
the CTS/RTS 2347 might cause you connection problems with some devices like playstation 4. I think the new firmware is late fixing this issue. I wouldn't push it above the 500
May 26, 2020Guru - Experienced User
"We used RTS=64 by default as it help on reduce on re-transmission and contention in noise environment and help when client is at location far from Orbi device. If your environment is not congestive or clients are not far away, RTS=2347 should be better."
