LIBrown175
Jul 26, 2022Aspirant
Cut xFin Equipment - add Netgear CM1200 modem with best Netgear router
Good day… I want to cut out xFin last piece of equipment and that’s the router/modem and their xFin system. I purchased a CM1200 modem and a AC1200 router. Not sure I have enough power to connec...
Jul 26, 2022Guru - Experienced User
Orbi AX 3, or 7 series would work best. For that size of home, a RBR and 1 RBS would be all that you need.
- LIBrown175Jul 29, 2022Aspirant
Thank you for your response…so an AX350 or AX353 or AX753 ( 3 or 7 series) with one satellite is what you are suggesting?
I see some with 2 satellites new and used at a discount. I’ve seen some videos where they have purchased a used system - seems to work well. Looking now thanks again
- FURRYe38Jul 29, 2022Guru - Experienced User
352 or 752 are ones with just one RBS. Yes.
