Meddyb
Jan 31, 2022Aspirant
débit fibre SFR sur RBS850
Bonjour Je viens d'acquérir un kit orbi routeur + satellite (RBR850 + RBS850) wifi 6 je suis fibré SFR box 8. Mon routeur SFR est dans le garage au rez de jardin et est connecté en filaire ( 15m...
Jan 31, 2022Guru - Experienced User
en anglais s'il vous plaît
You'll need to check with the mfr of the Pro PC on what connection rates are supported by the PC on wireless connections.
Meddyb
Hi
The Mfr is HP Iam using a HP EliteBook 830 G5
Intel dual band wireless AC-8265
I am sorry for the French
Hello
I have just acquired an orbi router + satellite kit (RBR850 + RBS850) wifi 6
I have a fiber connection
My ISP router is in the garage on the ground floor and is connected by wire (15m) to my RBR 850 which is located in the entrance hall and is configured in Access Point mode.
My satellite is located on the first floor on the “mezzanine” 4 meters from RBR850
wi-fi setup:
- 2.4GHZ on channel 1
- 5GHZ on channel 48
When I run a wifi test on the speedtest site from my iphone X, I have :
- 865Mbps on the Orbi Router
- 847Mbps on the Orbi satellite
When I run this same test in wifi from my pro computer 2 meters from the satellite, I top out at 150Mbps, but in general the speed is more like 105-110Mbps
The Orbi application tells me that my Pro laptop is connected to 5ghz
Could you help me determine what I need to change on my computer, because I suspect that the problem comes from him
thank you
- FURRYe38Jan 31, 2022Guru - Experienced User
Check the connection rate seen on the laptops wifi connection.
Ensure wifi and ethernet adapter drivers are up to date from the laptops mfr or the adapters mfr.
- MeddybJan 31, 2022Aspirant
How can I do that please ?
"Check the connection rate seen on the laptops wifi connection"
Open Control Panel in Windows and select Network and Sharing Center. Select the Change Adapter Settings.
Find the WIreless adapter and right select on it. (I don't have one howeever this works the same for either wireless or ethernet adapters.)
Select Status
Look at the Speed row.
