Kiki387
May 17, 2020Aspirant
Déconnexion AP mode Orbi RBK852
Good morning I always have disconnections, it starts with the satellite that disconnects but I placed it at 6m in open field. Then there is the router 2 or 3 times during the day sometimes the same ...
kildare
May 17, 2020Luminary
Your Apple TV is wifi 5 (802.11 ac) and its max speed is 867 Mbps on the 5 GHz band.
Did you try another wireless device with wifi 5 (ac) on the 5 GHz band?
Did you try another wireless device with wifi 6 (ax) on the 5 GHz band?
- Kiki387May 17, 2020Aspirant
My apple tv and gigabit ethernet so no worries,
otherwise I made measurements with wifi 5 and wifi 6 devices and it's the same result : 330Mbps instead of 900Mbps.
But I insist my problem is the disconnections, I have just connected the satellite in ethernet and I have the impression that it works better.
I saw on the forum that this model had problems in access point mode and blackhaul problems.- kildareMay 17, 2020Luminary
About the frequent disconnections, you might have a lot of electromagnetic interference due to other wireless devices... but if it's not so you might instead have a defective router or a defective satellite.
