Kiki387
May 17, 2020Aspirant
Déconnexion AP mode Orbi RBK852
Good morning I always have disconnections, it starts with the satellite that disconnects but I placed it at 6m in open field. Then there is the router 2 or 3 times during the day sometimes the same ...
May 17, 2020Guru - Experienced User
Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz. Channel 5 should not be set as a manual channel.
IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s).
Be sure that CTS and RTS values are changed to 2346 under Advanced Tab/Advanced Settings/Wireless Settings
Kiki387 wrote:Good morning
I always have disconnections, it starts with the satellite that disconnects but I placed it at 6m in open field. Then there is the router 2 or 3 times during the day sometimes the same fixed pink while it works.
I made in addition the following adjustments:
I have sonos at home on channel 1, so I'm on channel 5 in 2.4G, there are no nearby speakers so there is little noise.
Cohabitation 20/40MHZ disabled
cts/rts threshold at 2347 and short preamble mode for 2,4 and 5ghz networks as well.
Another problem I have a subscription ISP 1Gbs down and 500 Mbs up,
I check it on an apple tv connected in wifi via speedtest about 960 mbps downlink and 500 mbps uplink, but when I do the test in wifi with a wifi 6 device (iphone 11), I get painfully 330 mbps downlink while I have 500 mbps uplink, weird right?
On the forum there is a lot of disconnection problem on this product, isn't it a firmware problem ? ( I downloaded the last one )
Can you help meTranslated with www.DeepL.com/Translator (free version)
Kiki387
Good morning, sir,
The internet provider is bouygues telecom.
I made your settings but it's not better.
I specify that I'm in access point mode, so the settings are limited for example any unused channel on 5Ghz.
The house is 150m2 and the 2 systems are 7m apart.
There is no Wifi Neighbors near .
- Kiki387May 17, 2020Aspirant
the firmware is :
RBK852 Firmware Update V3.2.11.2_1.2.13
