Kiki387
May 17, 2020Aspirant
Déconnexion AP mode Orbi RBK852
Good morning I always have disconnections, it starts with the satellite that disconnects but I placed it at 6m in open field. Then there is the router 2 or 3 times during the day sometimes the same ...
May 19, 2020Guru - Experienced User
Kiki387 wrote:What is the building materials made of for the home? plaquatre
Can you move the RBS out farther? Try 30 feet?
it's the same
What channels are you using?
2 ghz --> 7 et 5 ghz 48< Try channel 1, 6 or 11. Don't use any of the other channels. 1, 6 and 11 are primary channels to use.
1 more than 100mfirmware 3.2.11.2-1.2.13 which is not automatically downloadable.
so the satellite is jumping all the time I unplugged it and the router works alone but after a while it lights up in fixed pink
You can downgrade the enstire system to v3.2.9.2 and see if anything changes.
Possible that you may have a bad RBS. I would open up a support ticket with NG and if nothing fails to stablize the RBS, ask about an RMA. Blanca_O
Kiki387
May 20, 2020Aspirant
Good morning, sir,
I tried the firmware 3.2.9.2_1.2.4 and the problem still exists
- FURRYe38May 20, 2020Guru - Experienced User
I would open up a support ticket with NG support and get help on this.
Seems like something if faulty with your system.
There is more recent FW avialble however I doubt it will help fix your issue. The problem seem to persist even downgrading. - Kiki387May 25, 2020Aspirant
I tried with the new firmware 3.2.15.25 but still problems so I unplugged the system for 1 day. I plugged it back in yesterday and miracle it's been working for 12 hours, isn't that due to some information that remains in memory?
To be continued .... - Kiki387May 25, 2020Aspirant
My rbr850 is behind an unmanageable switch
- Kiki387May 26, 2020Aspirant
DLINK DGS-1008P
- FURRYe38May 26, 2020Guru - Experienced User
Well this switch does have green ethernet features:
"Conserves Energy
The DGS-1008P 8-Port Gigabit Switch makes use of
D-Link Green™ eco-friendly technology, providing
energy savings, reduced power consumption, and
a longer product life without sacrificing operational
performance or functionality."Can you connect the RBR directly to the main host router and see if you still seen problems with out the switch connected? I have my 853 system in AP mode connected directly to my main host router with out a switch. Not seeing any disconnections thus far.
