The111
Jan 17, 2022Aspirant
Daisy-chained RBS750 always goes to "poor" backhaul status if "Connected Orbi" briefly loses power
I could not find my model in the dropdown selector. I have a RBR750 (let's call this R) with 4x satellites (RBS750) (let's call them A, B, C, D). Satellites A, B, and C connect directly to R. But D connects to A (i.e. daisy chain).
Somewhat regularly, A will lose power for 10 seconds. It reboots and gets back in working order very quickly. But D ends up with a purple status light, and when I check the "Attached Devices" page in my browser network monitoring UI, I see that D has a "poor" backhaul status (usually it is still connected through A, but occasionally it connects to R directly, at this point). It will stay in this poor status for days on end. It is not smart enough to try to fix the situation on its own. As far as I can tell, there is nothing I can do in the software UI to fix the situation. But if I simply power cycle A at the device, the problem gets instantly resolved after reboot.
Is this working as intended? It seems ridiculous that the system is aware that device has an issue yet makes zero attempts to fix it.
30 feet or more is recommended in between RBR and RBS📡 to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡From original post:
- The111Aspirant
Re: distances. I did some rough measuring.
A->R = 20ft (this is A's chosen connection path)
B->R = 30ft (this is B's chosen connection path)
C->R = 30ft (this is C's chosen connection path)
D->R = 30ft (D chooses against this path for some reason)
D->A = 40ft (this is D's chosen connection path)
Note that D chooses to daisy chain through A even though R is closer. This may because there is slightly more wall interference with D->R compared to D->A, I'm not sure. But note that D->R is completely adequate (and is actually the way the system used to work, since A was a late addition). Once I added A, D started choosing it. Which is completely fine with me: D will work great with either of D->R or D->A. The issue is that A briefly loses power sometimes, and D refuses to recover gracefully from the A power cycle unless I also manually power cycle D.
One workaround solution I'd be happy with is if I could force D to choose the D->R path. Then the A power loss/cycle would no longer be an issue, because the daisy chain would no longer exist. But... I don't think this is possible? The system chooses its own connection topology, I think?
A->R = 20ft (this is A's chosen connection path) <Distance is too close here. 30 feet or more maybe need here. Possible that the D RBS is confusing A with the RBRs signal when it should be connecting to next nearest RBS...C?
D->R = 30ft (D chooses against this path for some reason) <As it should and should connect to next nearest RBS. You may need to put more distance between the #D RBS and the RBR to help it ensure that it connects to the nearest RBS instead of the RBR or A RBS...Is that nearest RBS #A or #C
One workaround solution I'd be happy with is if I could force D to choose the D->R path. Then the A power loss/cycle would no longer be an issue, because the daisy chain would no longer exist. But... I don't think this is possible? The system chooses its own connection topology, I think? Depends on placement and how the RBS are turned on. If placement is out in a liner line from the RBR, then all thats needed is to turn ON the first nearest RBS to the RBR. Once it's ready, then turn ON the next RBS out from the 1st RBS and wait for ready, and so on and so on for the other RBS. This sets the system for Daisy chain.
I think distances and placement are a factor here for all RBS. I would play around with the distance of A RBS and get more distance between it and the RBR. Also you might test with Transmit power on the RBR and see if 50% changes the behavior your seeing.
What is the SQ Feet of your home?
Possible that you may have too much wifi signal around as well.
- The111Aspirant
Thanks for the suggestion. I may be able to move A a bit further away from R, which would presumably force D to connect directly to R instead, and thus solve my issue in a roundabout way. Out of curiosity, where do you see the 30ft or more rule? I don't see it in the page you linked or in any of the Netgear documentation.
And FWIW, I consider this ultimately an issue that could be resolved in software/firmware, since again the system works fine until a power cycle of a single unit messes up the topology, after which the system knows there is an issue but refuses to try to fix it. High level solutions to this problem would be (1) allow hardcoding the topology as a configuration option (2) design the system to attempt to fix poor backhaul status through at least a single reboot. Seems worth reporting to Netgear if there is a path here to do that.
The house is 3200 sqft living space, 2 stories. But one satellite (B) is in the attic (i.e. "3rd story") immediately next to a smart hub for our central air, since that hub has horrible reception and will not maintain connected status any other way. And another satellite (A) is in the garage. Which even though it is relatively close to R, there are enough walls and floors being passed through that the garage will not have a reliable signal without A being there, currently at the 20ft distance you say is too short. I will experiment with other locations in the garage if possible. I don't think I'm overprovisioned, because the signal is not full strength everywhere in the house. But it is usable everywhere, with this configuration, and full strength in most places.
