Burnssimon
Sep 23, 2023Aspirant
Daisy Chaining on RB350?
Hi all, I have an Orbi Router on the ground floor and satellites on the the first and second floors. Internet coverage is good, however the second floor device regularly loses connection to the ...
Sep 23, 2023Guru - Experienced User
If you place the RBS out in a line from the RBR, when the RBR is ON, and RBS are already turned OFF, turn on the closest RBS to the RBR first and let it sync. After it syncs, turn on the farther RBS from the RBR and let it sync, it should connect and sync to the other RBS thats closer to the RBR.
