Retired_Member's avatar
Retired_Member
Sep 20, 2021
Daisy Or Star Options
Looking at posts and help it suggests there is an option to disable daisy chain networking. I have a setup with main router in the middle floor , one satellite on bottom and one on the top floor so a...
  • Retired_Member's avatar
    Retired_Member
    Sep 20, 2021
    So I have jsut found another post that clearly explains that there are no options for daisy or star and it will select what it thinks is best though makes no sense on this setup given the distances.
    Still confused how the top satellite says its a wired when it clearly isn't. The app and website seem a little buggy with incorrect info at times even on this newer version. Still had a ghost satellite yesterday and had to remove again.
