Retired_Member
Sep 20, 2021Daisy Or Star Options
Looking at posts and help it suggests there is an option to disable daisy chain networking. I have a setup with main router in the middle floor , one satellite on bottom and one on the top floor so a...
- Retired_MemberSep 20, 2021
So I have jsut found another post that clearly explains that there are no options for daisy or star and it will select what it thinks is best though makes no sense on this setup given the distances.
Still confused how the top satellite says its a wired when it clearly isn't. The app and website seem a little buggy with incorrect info at times even on this newer version. Still had a ghost satellite yesterday and had to remove again.
Retired_Member
Sep 20, 2021So I have jsut found another post that clearly explains that there are no options for daisy or star and it will select what it thinks is best though makes no sense on this setup given the distances.
raven_au
Sep 21, 2021Virtuoso
Retired_Member wrote:So I have jsut found another post that clearly explains that there are no options for daisy or star and it will select what it thinks is best though makes no sense on this setup given the distances.
I don't know the actual orientation of the antenna inside the Orbi but keep in mind the closer to directly above or below the Orbi router will (probably) have a poor signal.
So it may be that another satellite does appear to have a better signal for a satelite than you think, even though you expect it to have a better signal from the Orbi router.
