Elieh
Apr 29, 2023Follower
Dead Orbi 750 router
Hello,
All of a sunder my Orbi 750 router died. When, I tried hard reset, when the white light came up, could not connect via wifi nor cable. The router just does not respond to anything.
1 Reply
Whats the power led on it doing? (color blinking etc)
You can try recovering it with tftp or nmrpflash.
are you on windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through using a tftp client. Use the built in one for windows 10 though. the video is more of an example of how its done.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
https://github.com/jclehner/nmrpflash
