VerneArase
Mar 17, 2020Apprentice
Dell Latitude 7480 and Orbi RBK853
My wife is now working at home, and her Dell Latitude 7480 isn't able to see my Orbi RBK853's networks. Has anyone seen this before, and is there any solution? -- Thanks, Verne
Mar 17, 2020Guru - Experienced User
Ensure the wifi adapter drivers ON the Dell are updated.
Doesn't see the SSID name at all?
Any special characters in the SSID Name?
- VerneAraseMar 17, 2020Apprentice
FURRYe38 wrote:What Firmware version is currently loaded?
Orbi firmware V3.2.10.11_1.2.12
Xfinity CGM4140COM firmware CGM4140COM_4.0p3s1_PROD_sey.
Doesn't see Fillory or Fillory-Guest.
I'll check after she finishes work to see if there are new drivers.
- FURRYe38Mar 17, 2020Guru - Experienced User
Let us know...
- FURRYe38Mar 18, 2020Guru - Experienced User
Let us know if you have seen any progress or not. You may need to get a hold of NG support and get further help and information on this.
VerneArase wrote:Orbi firmware V3.2.10.11_1.2.12
- VerneAraseApr 04, 2020Apprentice
Yeah, I had to disable 802.11ax <ouch!> to get the darn Dell to see the network.
Unfortunately, the wife's working at home on a Dell with out-of-date everything, and I don't have administrative access to update the Intel wifi driver, and her IT folks are reluctant to update the machine because of the current "stay-at-home" lockdown in Illinois and the fact that any modifications may brick her machine.
I wouldn't mind so much except that the main reason I bought a wifi 6 mesh systemw as to increase the backhaul speed (my iPhone 11 Pro Max is my only wifi 6 device), and you can't disable ax on the access point without disabling it in the backhaul.
