VerneArase
Mar 17, 2020Apprentice
Dell Latitude 7480 and Orbi RBK853
My wife is now working at home, and her Dell Latitude 7480 isn't able to see my Orbi RBK853's networks. Has anyone seen this before, and is there any solution? -- Thanks, Verne
Mar 18, 2020Guru - Experienced User
Let us know if you have seen any progress or not. You may need to get a hold of NG support and get further help and information on this.
VerneArase wrote:Orbi firmware V3.2.10.11_1.2.12
Xfinity CGM4140COM firmware CGM4140COM_4.0p3s1_PROD_sey.
Doesn't see Fillory or Fillory-Guest.
I'll check after she finishes work to see if there are new drivers.
VerneArase
Apr 04, 2020Apprentice
Yeah, I had to disable 802.11ax <ouch!> to get the darn Dell to see the network.
Unfortunately, the wife's working at home on a Dell with out-of-date everything, and I don't have administrative access to update the Intel wifi driver, and her IT folks are reluctant to update the machine because of the current "stay-at-home" lockdown in Illinois and the fact that any modifications may brick her machine.
I wouldn't mind so much except that the main reason I bought a wifi 6 mesh systemw as to increase the backhaul speed (my iPhone 11 Pro Max is my only wifi 6 device), and you can't disable ax on the access point without disabling it in the backhaul.
- FURRYe38Apr 05, 2020Guru - Experienced User
Ah...sounds like out of date stuff on the laptop then.
Well glad disabling if AX helped.
One thing to try, does her LT have a LAN port? If it does you could have her connect it via wired LAN then you could re-enable AX mode.
- VerneAraseMay 19, 2020Apprentice
Unfortunately her work area is quite a distance from the satellite, and the ethernet cable would have to cross a wood floor where there is public traffic.
Once she returns to the office, her IT guys can safely update her drivers - or get her a new laptop - I'm aquiring a define dislike for that laptop.
We brought her work monitor home, and it's 1080p - in order to get it working, I had to return to her office and get this wierd Dell docking box which accepted the plug coming out of the video cable from the monitor, and had two HDMI ports, a bunch of USB ports, and a female USB 3 port.
I tried the HDMI cables and they didn't work, but when I plugged in a USB 3 cable she suddenly had video.
Zounds ... who would think that USB 3 had sufficient bandwidth for both a USB hub and a 1080p video signal - and who would think of running video over USB when you have HDMI ports?
- FURRYe38May 20, 2020Guru - Experienced User
Even though USB 3.0 is fast. Very fast for data xfer between drives, it still can't really hold a candle to DVI or HDMI for video.
VerneArase wrote:Unfortunately her work area is quite a distance from the satellite, and the ethernet cable would have to cross a wood floor where there is public traffic.
- Mikey94025May 19, 2020Hero
VerneArase wrote:Yeah, I had to disable 802.11ax <ouch!> to get the darn Dell to see the network.
Have you also already set your CTS/RTS thresholds for both 2.4Ghz and 5Ghz to 2347? I found that fixed some wifi compatibility issues with my devices (with AX still toggled on).
