SparkyNuts
Dec 18, 2022Aspirant
Desktop - Wire to Orbi 750 Satellite or Use Desktop's Network Adapter?
Currently, we have Xfinity -> Xfinity Modem -> Orbi Router->Desktop via wire. Other stuff in the houses uses the WiFi, but the desktop is wired. Everything works well. Soon, we'll be switching ...
CrimpOn
Dec 18, 2022Guru - Experienced User
SparkyNuts wrote:
Soon, we'll be switching to fiber optic to the house. The point at which the fiber optic enters the house will be far from where the desktop is located. So the desktop will be connecting to the internet wirelessly.
Can you please describe what is behind the fiber entrance being "far from" the Xfinity entrance? You (the customer) told them "put it there, please"? The fiber company said, "we're installing it in this place and you can just 'deal with it'"? (My city has allowed a fiber company to compete with Spectrum and it is painfully obvious that telephone and cable enter all the houses in my subdivision from the rear, while the fiber has been placed down the street (front of houses). Am I likely to face your situation?
SparkyNuts wrote:
Looking at my device manager, it looks like I have the Intel WiFi 6 AX201 160MHz network adapter. It's advertised speed is 2.4Gbps, which is only half as fast as the advertised 4.2Gbps of the Orbi
This is a difficult topic:
- That advertised speed of 2.4Gbps applies
- Under perfect conditions, and
- When using 160MHz wide WiFi channels. The maximum channel width on the Orbi 750 is 80 MHz.
2.4Gbps over WiFi simply cannot happen.
- The advertised speed of the Orbi system is a marketing fantasy created by adding together all of the router radios maximum theoretical transmission rate. See the Product Data Sheet on page 4:
https://www.netgear.com/images/datasheet/orbi/RBK752.pdf The maximum theoretical connection rate to a single 5G WiFi device under ideal conditions (i.e. very close to the router) with a 2x2 MIMO connection is 1.2Gbps.
SparkyNuts wrote:
What's better for speed of connection, to wire the desktop to an Orbi satellite and turn off the desktop's WiFi adapter? Or skip the satellite and just use the desktop's adapter?
If the desktop is "Far" from the router, a wired connection to a satellite will be superior to a WiFi connection to a distant WiFi access point (the router). A better solution would be to install an Ethernet cable to wherever the router is moved. (but installing Ethernet is often impractical - it certainly is in my house.)
Dec 19, 2022Guru - Experienced User
Before fighting to much, I'd simply try it.
Thats a pretty solid system and a solid wireless card in the pc.
It might work fine and you have nothing to worry about.
