Canman93
Jan 30, 2021Aspirant
Desktop Connection Problems (Revisited) - RBK753S
I've had the Orbi 753S 3-Pack running for a few weeks and am very satisfied with the performance. My only problem, which I posted before, is that my desktop either doesn't connect, connects but no in...
Jan 31, 2021Guru - Experienced User
What happens if you disable AX mode on the RBR?
Might try replacing this adapter in the PC with something more up to date as a suggestion.
