kti19
Apr 16, 2022Aspirant
Device Can’t Find Main Network, but Finds Guest Network
I have an RBR850 with two RBS850 satellites. I recently got a new car that has a WiFi option for OTA updates, etc. However, the car cannot find my main home network as an “available network” to join. ...
Apr 17, 2022Guru - Experienced User
are other devices able to view the network in the garage?
Did you try disabling AX for the 2.4ghz network on the orbi?
Did you try changing wifi channels/
kti19
Apr 17, 2022Aspirant
Other devices have no issue viewing/connecting to the main network in the garage.
I just tried disabling AX for the 2.4ghz network with no luck.
I haven't tried changing WiFi channels, but that was next on my list as it seems several other posts with similar issues have been solved by changing the WiFi channels. The car was made in Europe (Volvo), so I'm curious if that has something to do with needing to use a different channel. The 2.4ghz channel is currently set to "Auto" and the 5ghz channel is set to 48. Any suggestions on what channel(s) I should try with the 2.4ghz?
- Mikey94025Apr 17, 2022Hero
Very mysterious. Another setting to try changing, just in case it helps your Volvo connect, is set CTS/RTS Threshold to 2347 (seems to improve compatibility with some 2.4Ghz wireless devices):
- Go to the web admin portal at http://orbilogin.com/
- Click to the Advanced tab, Advanced left menu, Wireless Settings
- Set CTS/RTS Threshold to 2347 for both 2.4hz and 5Ghz networks
- Press Apply
- kti19Apr 17, 2022AspirantThanks, happened to try that this morning as well (after doing some more digging in the community boards) and no luck. Can’t figure this one out! It’s not the end of the world if I have to leave to guest network open just for the car, but not ideal.
