BEBaker1
Sep 19, 2022Follower
Device Comnection
I have the RBR850 - a router and two satellites. Is there a way to force a device to connect to a specific unit (router or satellite)?
Brett
- ekhalilMaster
No, unfortunately not. According to wifi standards, it's the wireless device that should choose the best AP to connect to.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡Also try turning down the power output of the RBRs wifi radios from 100% to 50% and see if this changes anything. Under Advanced Tab/Advanced Settings/Wireless Settings can help some indirectly move devices to near by RBR or RBS.
Brett
