jbenson001
Apr 16, 2024Tutor
Device list per network
On my Orbi router, I have set up 3 networks, the main network, which also has the IOT network set up and the third is the Guest Network. I see there is a way to see connected devices but does not sp...
- Apr 16, 2024
I connected a tablet to an RBR750 IoT WiFi network. Notice the part outlined in red:
This says it was connected at 5GHz to the IoT.
Apr 16, 2024Guru - Experienced User
The RBRs web UI under Basic/Connected devices should give what network they are connected too using a web browser.
- jbenson001Apr 16, 2024Tutor
Thanks
This is an RBR850
The list shows the Connection Type and and Connected Orbi, but not the network name they are attached to.- CrimpOnApr 16, 2024Guru - Experienced User
- jbenson001Apr 16, 2024TutorThank you for the screenshot. That helped a lot!!
