parkdj808
Jan 26, 2023Aspirant
Device Losing Connection In Between Satellites RBR850
I have the RBR850 with router and satellite connected via Ethernet cable. Recently I added a second satellite which is connected wirelessly. When I walk around my house my phone is losing wifi connect...
Jan 26, 2023Guru - Experienced User
1. What actual firmware version is on the router and the satellites
2. What modem/gateway is the router connected to?
3. tough to know but is the wireless satellite connecting back to the other satellite or the router?
4. Are any other devices having issues or just the one?
- parkdj808Jan 27, 2023Aspirant1. V4.6.14.3
2. TBD spectrum internet
3. Is there a way to confirm? I would guess it is connecting to the other satellite as it is slightly closer and has less walls between the other satellite than it does the router.
4. Yes, we noticed this issue on multiple family members’ iPhones. Phone will lose wifi connection somewhere moving between router and satellite at times. Used to be flawless when only had one satellite. The house is 1800 square feet.- plemansJan 27, 2023Guru - Experienced User
What spectrum modem is it?
Is the satellite that is hardwired in running through a switch or directly of the RBR router?
What happens if you swap the satellites?
- parkdj808Jan 27, 2023AspirantSpectrum modem EU2251
Hardwired satellite is running directly to RBR router
I have not tried swapping the satellites? If I do so, it will automatically set up correct?
Have you heard of other’s experiencing this issue much with devices dropping when in between range?
- plemansJan 29, 2023Guru - Experienced User
1800sq ft shouldn't need a router +2 satellites. I can cover my home (3300sqft) with a router and 1 satellite without issues.
You might actually have to much coverage which is hurting roaming.
Did you try swapping them?
- parkdj808Jan 29, 2023AspirantI have not tried swapping satellites yet. Will try next. If I swap, it’s just plug and play? Nothing else I need to do?
I added the second satellite because my signal was super weak in my kitchen area. And no signal at all in the backyard area just outside my kitchen. My ring camera outside the kitchen could not even connect. After adding a second satellite, it corrected this issue.
