rkatanasho
Oct 27, 2021Tutor
Device not connecting to closest satellite
Last week I bought AX6000 (AX6000 Tri-band) with 2 satellites to replace my Google Wifi as I upgraded my bandwidth to 1Gbps and wanted to take advantage of WiFi 6 higher. Hardware Version R...
Oct 27, 2021Guru - Experienced User
It's up to devices to pick and choose where they connect too. You would have to reduce the Transmit power from 100% to 50 or 25% as a test to see if this helps with getting some devices to connect to the RBS.
- rkatanashoOct 27, 2021Tutor
Thanks for the help and response.
The satellites are more than 30 feet away (9metres +) from the router.
The internal of the house is wooden frame with Gyprock walls (with a level of insulation); though nothing like brick or concrete.
Do you know if the having a device connected via ethernet has an impact of the behaviour of the Wifi?
I have done some experimentations and found:
* when I removed the hardwired devise and reset the system, after a short period the Apple TV devise in the room connected to the closer satellite.
* As some of the devices were flactuating between the router 2.4G (further away) and 5G on either router of satellite, I configured the devices that allow to only be on signle 5G band and they now connect to the closed satellite.
For a very expensive devise (in AUD about $1750), i wasn't expecting these type of issues especially that I never had issues with the cheaper Google nest Wifi.
