brandobot
Feb 02, 2022Guide
Device not showing up under "Attached Device" in console
On my RBR850, I connected a device via wifi. On the device itself (while connected through bluetooth), I can see my device has an IP of 10.0.0.83. From another device on my network, I can ping this d...
Feb 03, 2022Guru - Experienced User
What device are you referring too?
brandobot
Feb 03, 2022Guide
Firmware 4.6.3.16
Modem is Arris bgw210.
The device connected is a Bobcat 300 Helium miner.
- FURRYe38Feb 03, 2022Guru - Experienced User
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopI recommend option #2.
What browser are you using?
Does the Orbi app experience same thing with this device not appearing?
Is the device connecting to the RBR or RBS that you can tell? Look at the RBS web page as well.
Might review this as well:
- brandobotFeb 03, 2022GuideMy modem has wifi disabled. I have ip passthrough configured and my orbi is in router mode.
I’ve used chrome and safari browsers on my windows, mac and iphone. I’ve also tried the Orbi app from iPhone. The device is closest to my rbr, but i can check the rbs page- FURRYe38Feb 03, 2022Guru - Experienced User
Also ensure the devices FW or SW is up to date on the device?
