brandobot
Feb 02, 2022Guide
Device not showing up under "Attached Device" in console
On my RBR850, I connected a device via wifi. On the device itself (while connected through bluetooth), I can see my device has an IP of 10.0.0.83. From another device on my network, I can ping this d...
ekhalil
Feb 03, 2022Master
Do you have SPC (Smart Parental Control) activated?
When the new SPC is active the way the Orbi app handles attached list and the list’s format is different.
I noticed the same issue with devices not showing in the attached list (of online devices) and the device will show as not online although the device is online!. What I do to get the device again is to “remove the device” then with the next refresh it will start to show correctly in the list.
