lxu2011ct's avatar
lxu2011ct
device on RBS750 ethernet port does not show on network
Hi, I bought rbr750 with two rbs750 and just set them up. The two satellite are connecting to route wirelessly and everything looks working fine. However, when I connect a device using ethernet cable...
  • lxu2011ct's avatar
    lxu2011ct
    Jan 21, 2021
    I got the problem solved by connect the NAS to a router with 10.0.0.1 ip address. After connecting a PC to the same router, I can log into the NAS and changed the Static IP setting to Dynamic one. Then when I put the NAS back to Orbi, the NAS is online and get the correct IP address. Thanks.
