bmxsteve
Jan 11, 2021Aspirant
Device wifi speeds slow-RBR750
Hello, I have ATT Fiber 1000 with a BGW210-700 modem and an Orbi RBR-750 with one wired backhauled RBS50 and two RBS750 wireless satellites. My concern is that my wifi settings might not be optima...
Jan 11, 2021Guru - Experienced User
Most iphones and WiFi 5 devices will max out at around 400-500Mbps due to the antenna design, 2x2. Even my 12 Max gets around 400 to 500ish speeds. I have a Asus GT-AX11000 router that is 4x4 that I can use as a wireless client and it can get 900Mpbs speeds. Connection rate between the Orbi AX and the Asus is around 1800Mpbs as well. Something my 12 Max phone doesn't get.
You can check the connection rate with installing wifisweetspots app on your wireless devices.
