MrFendster
Jul 19, 2021Aspirant
Device won't connect - AX6000 RBR850 FW V3.2.18.1
Trying to reconnect a Netgear WNCE2001 wifi adapter to my Orbi. It has previously been connected now it doesn't show up on the connected devices. A notification is generated that a new device has bee...
- Jul 28, 2021
Ah Hah ! Excellent. I'll reconfigure an old Netgear N300 router as a bridge.
Thank you so much for your persistence with my problem ;-)
Jul 20, 2021Guru - Experienced User
Try disabling AX mode on the RBR...
- MrFendsterJul 20, 2021Aspirant
Thanks Furry, I've searched the router and can't find any switch for AX mode ... can you point me in the right direction, please ?
- FURRYe38Jul 21, 2021Guru - Experienced User
Basic Tab/Wireless settings. Uncheck the check box next to 2.4Ghz...
- MrFendsterJul 27, 2021Aspirant
So I've done that and what has happened is that all of the 2.4G connections are blocked. Why does the device create a connection like 192.168.x.x and not a connection to the router like 10.0.x.x ?
Thanks in anticipation.
