MrFendster
Jul 19, 2021Aspirant
Device won't connect - AX6000 RBR850 FW V3.2.18.1
Trying to reconnect a Netgear WNCE2001 wifi adapter to my Orbi. It has previously been connected now it doesn't show up on the connected devices. A notification is generated that a new device has bee...
- Jul 28, 2021
Ah Hah ! Excellent. I'll reconfigure an old Netgear N300 router as a bridge.
Thank you so much for your persistence with my problem ;-)
Jul 20, 2021Guru - Experienced User
Try disabling AX mode on the RBR...
MrFendster
Jul 20, 2021Aspirant
Thanks Furry, I've searched the router and can't find any switch for AX mode ... can you point me in the right direction, please ?
- FURRYe38Jul 21, 2021Guru - Experienced User
Basic Tab/Wireless settings. Uncheck the check box next to 2.4Ghz...
- MrFendsterJul 27, 2021Aspirant
So I've done that and what has happened is that all of the 2.4G connections are blocked. Why does the device create a connection like 192.168.x.x and not a connection to the router like 10.0.x.x ?
Thanks in anticipation.
- FURRYe38Jul 27, 2021Guru - Experienced User
You'll need to read thru it's user manual and see how to set it up to work with the router. Seems like it may not be set up right or not handling the IP addressing it should be getting from the wifi system. Possible that this one device may not work well with Orbi AX systems.
Good Luck.
