MrFendster
Jul 19, 2021Aspirant
Device won't connect - AX6000 RBR850 FW V3.2.18.1
Trying to reconnect a Netgear WNCE2001 wifi adapter to my Orbi. It has previously been connected now it doesn't show up on the connected devices. A notification is generated that a new device has bee...
- Jul 28, 2021
Ah Hah ! Excellent. I'll reconfigure an old Netgear N300 router as a bridge.
Thank you so much for your persistence with my problem ;-)
schumaku
Jul 28, 2021Guru - Experienced User
The WNCE2001 resp. all Ralink RT3052 was OK on Windows XP, but became cumbersome on later WIndows versions. One one hand, current drivers are not avilable for decent Windows builds. On the other hand, often Power Saving had to be disabled. Afraid, its more or less a relict of the past.
MrFendster
Jul 28, 2021Aspirant
- FURRYe38Jul 28, 2021Guru - Experienced User
Glad you got something working. Enjoy.
