MikeHalsey
Oct 10, 2023Initiate
Devices connected to Orbi satellites cannot see Spotify
Hi, I have a new Orbi 850 (wouldn't let me select that exact one in the associated products box) router with two satellites. The Orbi router is in my gîte (outhouse) where my office is, connected to...
Oct 10, 2023Guru - Experienced User
Are the spotify and all other devices on same network? If you have them separated between the Main and Guest Network, this won't work as the GN has isolation from the main network.
MikeHalsey
Yes, they're all on the guest network for fairly obvious reasons as there's no way to know if they've been getting any security updates. That's except for the two on ethernet, and these will probably end up on the guest Wi-Fi for the reason stated above.
I understand that devices on the guest network are prohibited from seeing one another by the Orbi, but aside from being on a different IP range now they were all on the guest network before and everything worked fine.
There's also the question of why the ethernet connected speaker in the gîte, connected directly to the router, can be seen, but the ethernet connected speaker in the house, connected directly to a satellite, cannot be seen.
