DanyP
Aug 19, 2022Aspirant
Devices connected to Satellite RBS850 loses WLAN connection
Hello all, have a RBS850 in the attic. This is connected by wire to the LAN. Since I moved the RBR850 router to a different location in the basement, the devices connected to the RBS850 keep losing ...
- Aug 23, 2022
I think the problem is solved. I have not experienced another wifi outage since 24 hrs. I have deactivated the RBS850 again and reactivated it after about an hour. During the activation I pressed the reset button. In difference I used a paper clip and not the wire which I had used before. I was clearly paying attention to whether the button was responding or not. It takes about 20 minutes until the RBS850 was back online. I thank everyone for the support. If I do not contact you again the problem is solved.
Aug 21, 2022Guru - Experienced User
Can you disconnect the RBS from the switches and see if the behavior changes?
DanyP wrote:
There are two switches between the RBR850 and the RBS850. Firs node GS108Ev3 and second node GS105Ev2, both with the latest firmware.
DanyP
Aug 22, 2022Aspirant
I did. The RBS850 has connected to the RBR850 via WLAN. The quality of the connection is output as 'poor'. The behavior is the same as when the RBS850 is on the LAN. Suddenly the connection is gone.
- FURRYe38Aug 22, 2022Guru - Experienced User
If your RBS is in the attic, is this attic space well cooled and ventilated?
Sounds like you may have a faulty RBS.
I would contact NG support and see what your options are:
- DanyPAug 23, 2022Aspirant
- FURRYe38Aug 23, 2022Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
