DanyP
Aug 19, 2022Aspirant
Devices connected to Satellite RBS850 loses WLAN connection
Hello all, have a RBS850 in the attic. This is connected by wire to the LAN. Since I moved the RBR850 router to a different location in the basement, the devices connected to the RBS850 keep losing ...
- Aug 23, 2022
I think the problem is solved. I have not experienced another wifi outage since 24 hrs. I have deactivated the RBS850 again and reactivated it after about an hour. During the activation I pressed the reset button. In difference I used a paper clip and not the wire which I had used before. I was clearly paying attention to whether the button was responding or not. It takes about 20 minutes until the RBS850 was back online. I thank everyone for the support. If I do not contact you again the problem is solved.
Aug 30, 2022Guru - Experienced User
You might update FW as well:
v.5 has known issues with mysterious reboots and disconnections.
