LTEGuy's avatar
LTEGuy
Star
Oct 19, 2022
Devices do not connect to RBS750
I have a RBK752 system running fw version 4.6.11.1
The app shows that the satellite is connected to the router. However no devices are connected to the satellite. No matter how close devices are to the satellite, they still only connect to the router.
Any ideas what the issue can be?
Thanks.
  • FURRYe38's avatar
  • plemans's avatar
    Are you checking through the app or logging into the satellite through the browser?
    I've seen a couple reports before of it not displaying right on the app but logging into the actual satellite showed devices connected.
