Mikepedley
Sep 23, 2023Aspirant
Devices dropping from network
Any ideas please? I am running small home network, comprising of 2 x Microsoft Windows 11 laptops, 1 x Raspberry pi file servers running samba share, 1 x Raspberry pi running Urbackup server with 2 ...
Mikepedley
Sep 24, 2023Aspirant
thanks for reply. Sorry should have given more detail on this
its the windows network discovery program which is now not working, phones ok Tablet has odd hiccup
I have a few Raspberry pi file servers that i use for centralised storage and backup, i am familiar with this, re my job (retired). My Daughter-in-Laws and sons also use this storage to copy of data from there phones and laptops - mainly pictures... lots of pictures. they come over scan network and copy to their labelled storage. , but if they cant see devices to connect to they tend to panic. ok if I'm around but unfortunately my health is not good and have spent a lot of time in hospital. this also applies to my wife who is not computer literate.
looking at the Orbi web interface and the phone app i can see all connected devices.
Access control looks disabled, there is nothing in the tick box that say turn-on. I can see all devices in list , nothing is blocked. No setting in blocked sites and services
Many thanks, hope this helps
CrimpOn
Sep 24, 2023Guru - Experienced User
Having never installed Bitdefender, I have no idea what it may have done to Windows settings. Might be worth a few minutes verifying that Windows Discovery is actually enabled.
I use various programs to scan the local network, including Slitheris Network Discovery (free)
Could you please give that program a try and see if it "finds" the resources?
It is not blazing fast, but is pretty thorough.
- MikepedleySep 25, 2023Aspirant
Many thanks,
i have verified the windows network setting, including resetting the firewall, the required SMB settings etc. all seems correct
i installed the network discovery software you suggested and it scan and found all the devices i have been looking for.
Given this it looks like windows settings problem , as you suggested things Bitdefender changed.. but i did try a fresh windows laptop that didn't have AV installed and it didn't fine anything?
