Mikepedley
Sep 23, 2023Aspirant
Devices dropping from network
Any ideas please? I am running small home network, comprising of 2 x Microsoft Windows 11 laptops, 1 x Raspberry pi file servers running samba share, 1 x Raspberry pi running Urbackup server with 2 ...
BullMoon
Sep 25, 2023Apprentice
Yes, so I was correct. I Task Manager killed the Explorer.exe process and restarted it and now all my servers show up as they should in Explorer under the Network folder. But that was the solution this time for this version of the problem. I figured if the command line net view could see them, but explorer couldn't, it was explorer getting confused. As I said, in general, I find that entire thing unreliable and an unfortunate networking time waster with Windows. 😞
Mikepedley
Sep 26, 2023Aspirant
Give me Unix any day
- BullMoonSep 26, 2023Apprentice
Right, I figured restarting Explorer was not going to help your problem. Here's a few links that might have a solution.
https://appuals.com/how-to-fix-network-discovery-not-working-on-windows-10/
https://www.makeuseof.com/fix-network-discovery-not-working-windows-10/
- MikepedleySep 28, 2023Aspirant
thanks, i am on windows 11 but the concepts are the same.
i have tries these find these, i also found them when googling
- MikepedleySep 30, 2023AspirantOk. Rebuilt wife's laptop. Still no joy
Now very confused.
When I set the Orbi back to factory settings, does this completely reset everything? Manual says top level bits? Wondered if any bitfender / Armour changes are still set?
