joebacca123
Jan 02, 2023Aspirant
Devices keep going to 2.4ghz
Hi, I just purchased a AX3000 - RBK653S set. Unfortunately there is no way to "unbundle" the ssid for 2.4 and 5ghz from what I could tell. The Wifi signal is good wherever I go, but none (with the ex...
Jan 03, 2023Guru - Experienced User
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR and RBS🛰️ to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite ‌‌🛰️
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Also try turning down the power output of the RBRs wifi 2.4Ghz radios from 100% to 50% or 25% and see if this changes anything. Under Advanced Tab/Advanced Settings/Wireless Settings
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
joebacca123 wrote:
Hi, I just purchased a AX3000 - RBK653S set. Unfortunately there is no way to "unbundle" the ssid for 2.4 and 5ghz from what I could tell. The Wifi signal is good wherever I go, but none (with the exception of my phone+TV for some reason) of my devices are connecting to 5ghz. Can the ssid somehow be split? I have devices that require the 2.4ghz so turning it off is not an option. Thanks
