springcleaning2
Jul 30, 2024Aspirant
Devices know password automatically?
Orbi WiFi 6 System - AX6000 - 2 pack Delivered and installed today. All is working fine. Was able to connect my laptop and my iPhone to the new WiFi network name using the new password I assigned. ...
CrimpOn
Jul 30, 2024Guru - Experienced User
Assuming that the WiFi SSID and password for the Orbi are different than the previous WiFi system, I would look to Apple for an explanation.
Are these the only WiFi devices? If there are other devices, how were they connected to the Orbi system? i.e. if that iPhone is the only device which did this, perhaps Apple has some capability for sharing network information. Having no iPhone, I have no idea what such a feature might be called.
p.s. Many users deliberately set up a new WiFi system with SSID and password that exactly match the system being replaced. This serves two purposes:
- Existing devices will connect to the new system immediately without requiring any configuration. With many Internet of Things (IoT) devices being tedious to configure, this can save substantial time and effort.
- If the user decides to "go back" to the previous WiFi system, the instant it is plugged in every WiFi device will connect automatically without requiring configuration.
If the user has made a significant number of IP address reservations (on the LAN Setup page of the web interface), the usual practice is to make all those configuration entries on the replacement system before creating the WiFi credentials. That will ensure that devices do not get IP assignments that are unwanted.
I have had the same WiFi credentials for 20 years.
- springcleaning2Aug 07, 2024Aspirant
Hello!
Yes, the Wi-Fi SSID and password for the Orbi are different than the previous Wi-Fi system. Thanks for the suggestion to reach out to Apple. Unfortunately, they has no explanation and were no help.
The 2 iPhones are not the only Wi-Fi devices. I connected my HP laptop only after I had entered in the password. You are correct, my mom's iPhone is the only device that automatically selected the new SSID and automatically knew what the password was.
My initial plan was to set up the new Orbi with SSID and password exactly matching the system being replaced for the reasons you listed below. However, I decided not to do that because I wanted to test the Orbi system out.
I'm not too savvy in technical language, so not sure what you mean by address reservations.
Thanks so much for helping me troubleshoot. It's annoying to me that it happened.
