rcmack's avatar
rcmack
Devices not connected to satellites - RBK753
Today I have noticed two issues with my Orbi RBK753 system with a router and two satellites.    1. I connected by old TP-Link Archer AC2800 via ethernet to one of the satellites, disabled DHCP and ...
  • FURRYe38's avatar
    Jul 03, 2021
    Did you power off both RBR and RBS after updating FW for 30 seconds then back ON?
    What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
    Also try turning down the power output of the RBRs wifi radios from 100% to 50% and see if this changes anything. Under Advanced Tab/Advanced Settings/Wireless Settings
