Allestis
Aug 16, 2021Aspirant
Devices not connected to satellites - RBK853 RBR850 RBS850
Hello all I've looked at threads discussion issues with devices not connecting to satellites however I can't match my situation to those. Firstly the config options I see for my set up don't seem...
- Aug 26, 2021
Thank you very much for replying.
After adjusting down to 50% my app still showed no connected devices but a poorer signal from the router (no surprise)
The big surprise was that after bumpgin back to 100% when I looked at each satelite directly from the admin console it did report that I had connected devices.
It seems that the IOS app does not report the connected devices whereas the admin console does show them.
Thanks again for your help.
Aug 23, 2021Guru - Experienced User
Try turning down the power output of the RBRs wifi radios from 100% to 50% and see if this changes anything. Under Advanced Tab/Advanced Settings/Wireless Settings
Allestis
Aug 26, 2021Aspirant
