Allestis's avatar
Allestis
Devices not connected to satellites - RBK853 RBR850 RBS850
Hello all   I've looked at threads discussion issues with devices not connecting to satellites however I can't match my situation to those. Firstly the config options I see for my set up don't seem...
  • Allestis's avatar
    Allestis
    Aug 26, 2021
    Thank you very much for replying.
    After adjusting down to 50% my app still showed no connected devices but a poorer signal from the router (no surprise)
    The big surprise was that after bumpgin back to 100% when I looked at each satelite directly from the admin console it did report that I had connected devices.
    It seems that the IOS app does not report the connected devices whereas the admin console does show them.
    Thanks again for your help.
