javiersalasf
Oct 30, 2024Aspirant
Devices not connected to specific satellite | ORBI RBS750
Hi I'm looking for help, some time ago I bought a new satellite to add in my orbi network having a total of 3 satellites and 1 router (RBR750). When I added this satellite, I immediately noticed tha...
javiersalasf
What is the distance between the router and satellite(s)
1st Satellite is around 36ft from router
2nd Satellite is around 15ft from router
3rd Satellite is around 40ft from router
All of these are in individual rooms that are concrete walls
Does this happen with the RBS turned OFF?
I tried with one RBS turned off and yes, issue still hapenning
Does this happen with both wireless and wired devices?
It only detects wired device, wireless device is not attaching but I have seen behaviors before troubleshooting the issue and restarting where the devices are not showing in the android app or through the browser even with a wired device
What channel configurations are currently set on the router?
Based on Wireless Settings in the router, these are the channels
2.4ghz - Automatic channel
5ghz - 48
Yes - I tried that few time ago but issue still occurs, for some time it was working fine but I had to do a restart and I started to notice the issue again
I will try reverting to V7.2.6.21 and monitor if the issue still happens with this version
Oct 30, 2024Guru - Experienced User
"2nd Satellite is around 15ft from router" Maybe too too close to the router.
All of these are in individual rooms that are concrete walls" this will play a roll in how devices connect and the system operates. Concrete and steel will inhibit good signal travel and coverage and possibly cause connection issues with devices connecting to the RBR or RBS. Something that is hard to control.
Not sure if adjusting the power on the RBRs web page could help or make it worse since you have concrete in the mix:
Under Advanced Tab/Advanced Settings/Wireless Settings
Can give this a try and see.
- javiersalasfOct 30, 2024Aspirant
Hi
The house is 1510 sq ft. I will try that too and give my feedback!
Thank you
- FURRYe38Oct 30, 2024Guru - Experienced User
Might try turning OFF one RBS. Normally for a non concrete home, the RBR and maybe just one RBS would be needed, if that. However concrete in the mix here. 🙄
For now I have downgraded to V7.2.6.21. I will monitor and see if this works or if change the suggested settings you have mentioned.
Thank you
