user42069
Jul 05, 2022Follower
Devices not connecting to CBR750
Hello, I have a CBR750 router/modem combo, and it was working perfectly fine for the past few months . There was an internet outage from the ISP today, but the internet has since been restored. I attempted to reboot the router, and about 10 devices reconnected, including the laptop I'm writing this on now, and a few devices that were using a wired connection. I have about 30-40 devices that should be connected but aren't, with most of them being smart switches, a smart thermostat, and Ring cameras. I have changed several different settings to get the wifi to work, including turning on and off the AX mode, adjusting the CTRS threshold to 2347, and retyping the SSID password just in case it somehow changed. None of this worked however, and I'm not sure where to go next. I've had a similar problem like this before, but it usually resolved itself after I turned on and off AX mode, but that didn't work this time. Is there anything you all have done to resolve this? Thanks.
1 Reply
Are your satellites connected?
Did you try a simple factory reset?
