Dazza762
Aug 27, 2021Luminary
Devices not connecting to satellite
I've got a satalite set up in my office. It's connected properly to the router but none of the devices in my office are connecting to it. They all connecting to the router unit which is in a differen...
- Aug 27, 2021
FURRYe38 wrote:What Firmware version is currently loaded?
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?What is the size of your home? Sq Ft?
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡Also try turning down the power output of the RBRs wifi radios from 100% to 50% and see if this changes anything. Under Advanced Tab/Advanced Settings/Wireless Settings
Distance isn't an issue. Less than 30 ft. I seem to have fixed it by doing a full reset of the satellite in question.
Aug 27, 2021Guru - Experienced User
Dazza762
- FURRYe38Aug 27, 2021Guru - Experienced User
lf less that 30 feet, it's not recommended to have the RBR and RBS in less that 30 feet. The signal is strong enough to carry past 30 feet on either unit. 30 feet is recommended starting point or farther.
- Dazza762Aug 28, 2021Luminary
FURRYe38 wrote:lf less that 30 feet, it's not recommended to have the RBR and RBS in less that 30 feet. The signal is strong enough to carry past 30 feet on either unit. 30 feet is recommended starting point or farther.
I don't know precisely how far the RBS is from the RBR. It's a room over from it on a diffrent floor of the property. The wifi signal drops off dramatically as soon as you leave the room the RBS is in though. I have 500mb line and in the same room as the RBS I can get 400-450mb but only 50-100mb in the room next door. I'm a little surprised and disappointed about it. Most of what I'd read about the system suggested the wifi signal would be a lot stronger and consistent than it's proving to be.
Both 2.4 and 5ghz channels are transmitting at 100% which was the power they were set to out of the box.
- FURRYe38Aug 28, 2021Guru - Experienced User
Possible the RBS is faulty. I'd contact NG support and see what your options are. Ask about an RMA.
