Clfleck
May 27, 2022Aspirant
Devices not connecting to satellite
Orbi mesh 750 with 2 satellites. No devices connect to the satellites and only to the main router. House is 3500 sq ft so I need those satellites to work. Router is up to date. Any way to get devices ...
May 27, 2022Guru - Experienced User
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
https://kb.netgear.com/000061709/Where-should-I-place-the-Mesh-WiFi-satellite-of-my-Nighthawk-Mesh-WiFi-6-and-Tri-band-Mesh-WiFi-6-products 📡
https://youtu.be/UR0viMLISz4
Also try turning down the power output of the RBRs wifi radios from 100% to 50% and see if this changes anything. Under Advanced Tab/Advanced Settings/Wireless Settings
Clfleck
V4.6.5.14 update model RBR 750. The modem is a netgear CM1000V2 that I own, not leased from cable company.
The first satellite is approx 53 ft from the router. Second is another 30 ft or so past it.
How do I find that setting to change the percentage from 100 to 50? Is it on the orbi app or do I have to log on to a desktop version? Can’t find that setting in the app.
- FURRYe38May 27, 2022Guru - Experienced User
Under Advanced Tab/Advanced Settings/Wireless Settings using a web browser.
- ClfleckMay 27, 2022AspirantI can’t seem to get into the orbilogin page. I’m on the network and it won’t get past asking for the username/password. It will take me to a page to change my admin user/password. I tried that. Still no go. Tried a different browser. Nope. Can’t passed the log in to get to the screen to change settings. Don’t know what to do.
Sounds like your system was caught up in the auto update debacle. You can wait for NG to do something, contact NG support and ask for there help or do a factory reset and setup from scratch with a wired PC and web browser connected to the RBR to re-gain more immediate access.
