Cholla07
Jul 26, 2022Aspirant
Devices not connecting to the satellite
Hi I'm having the same problem. I have 3 satellites. One on each level at least and all my devices are withing recommended distance to the satellite. I even have an Alexa sitting right next to a s...
Jul 26, 2022Guru - Experienced User
You have a 7 series Orbi system?
Is the RBS ethernet connected or wirelessly connected to the RBR?
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Also try turning down the power output of the RBRs wifi radios from 100% to 50% and see if this changes anything. Under Advanced Tab/Advanced Settings/Wireless Settings
Cholla07
Firmware Version v4.6.8.2_2.1.9
RBR750 Model
Almost all other setting are default beyond primary passwords.
Version Fios internet hard lined directly to the Orbi router. There is no other router or wireless signal device diverting the traffic before it his the Orbi Main router hub. Only device is a netgear mutli-port switch for cat hard line connectivity.
Don't have Auto channel as an option for 5Ghz, set to 48.. 2.5GH set to channel 1. Adjusted the output power to 50%.
No change in results though. All devices are still connecting primarily to the main router only.
- FURRYe38Jul 26, 2022Guru - Experienced User
What is the distance between the router and satellite(s)?
- Cholla07Jul 26, 2022Aspirant
less than 30 feet. All Satellite display full signal strength as well.
Maybe why.
